Author Topic: Table size for 15mm Magna?  (Read 633 times)
daveparish
« on: April 19, 2023, 03:00:13 PM »
Got players at our club with 15mm armies who want to move up from Pacto to Magna. I know 25mm Magna uses a 180cm x 120 cm table. Would you make this 120cm x 80cm for 15mm (...assuming same number of points eg 7000 points)
Re: Table size for 15mm Magna?
« Reply #1 on: April 19, 2023, 05:35:26 PM »
Yes.
daveparish
« Reply #2 on: April 19, 2023, 06:04:17 PM »
Thanks :D
daveparish
« Reply #3 on: May 16, 2023, 03:51:32 PM »
So we tried the 120 x 80 table size last night. Still deploying 6BW back from the centre line. The deployment zone felt very cramped - for instance if you put a mounted TUG in front of the camp there wasn't room for a second one behind it (ie in reserve between the front TUG and the camp). Doesn't stop you deploying but needs thought/ planning just to get everything down roughly where you want it. Is this deliberate (to force choices) or is it OK to make the table a bit deeper?
« Reply #4 on: May 18, 2023, 11:53:13 AM »
It is okay to make the table deeper. Indeed 120 x 90 is probably a good choice.
daveparish
« Reply #5 on: May 18, 2023, 05:03:09 PM »
Thanks Richard
Mago
« Reply #6 on: November 19, 2023, 10:22:18 PM »
Hi
In the Compendium rules the Magna size is 4ft by 3ft, so 122 cm x 91.5 cm so using that would give you the depth you need. For metric rounders 120 cm x 90 cm is fine, Imperials can use 4ft x 3ft.
