Path of Charge, Countercharge and Shooting
Started by Hayung_is, August 20, 2024, 03:20:48 AM
Hayung_is
Hi all,
Still trying to figure some sneaky ways to get extra shots from archer units before they get pounded into the ground. So trying to understand when path of charge provides shooting opportunities.
This one refers to the figures on page 64 of the PDF rulebook - the gallic warriors charging parthian infantry and parthian cataphracts. It clearly shows the path of charge coming within 1BW of the infantry even though the cataphracts block contact via countercharge or intercept.
My question is: if the infantry in this situation were shooters - could they still shoot at the chargers as if they had come within 1BW? as it appears the path of charge does as this is defined before countercharges and there doesn't appear to be any suggestion that the PoC is altered by countercharge/intercept.
In this case as the path of charge is within 1 BW they could shoot (if they were shooters); 2 bases shooting in this case.
