Trastámara Spanish
Started by stuuk, March 14, 2019, 09:43:36 PM
stuuk
The Landsknecht hakenbuchsenschutzen - it says 'see note', but there is no note
The note should be  **Instead of skirmishers, up to 2 handgunners can be folded into pike formation by adding "Experienced/Firearm" to those troops.  There are two ways to represent this: 1) ideally replace 1 pike or halberd with a handgunner, or 2) to avoid rebasing place a handgunner skirmish base in front of the file containing them.
I will add an errata.
stuuk
Thanks, the 'Upgrade landsknecht hakenbuchsenschutzen' maybe needs altering too for the maximum then?
It looks like i can have 8 'upgraded landsknechts', but only half of their accompanying skirmishers could be 'Upgrade landsknecht hakenbuchsenschutzen'
probably it should be just a maximum of two, unless you want to force me to buy the regular landsknechts as well?
Anyway, have a look and hopefully you can see what I mean, cheers!
Quote from: stuuk on March 15, 2019, 06:25:22 PM
The intention is that you can only by upgraded landsknecht hakenbuchsenschutzen if you use landsknecht hakenbuchsenschutzen in both TuGs.
mad lemmey
Thought Taramasalata upgrade was crusty warm white pitta bread and a squeeze of lemon?
List bounced...
stuuk
Literally anything is better than finding a hakenbuchsenschutzen in your food..
