Uhm...ok, in this way you "fix" the ranges to keep the 40mm base size. I think that half base size, as It Is now(20 mm), works well for pacto. At the beginning we were quite confused, but with playing it was fine enought. I think that half base (20mm) works very well for pacto expecially because you can play in a really small table: this Is the most important thing imho, as It helps also training new players, since pacto was aimed at that.
