Late Roman Shields (Chi-Rho Symbols)
Started by IanN, January 05, 2022, 12:43:00 PM
IanN
Am seeking info on use of Chi-Rho patterns on late Roman shields - specifically the Sub-Roman patterns as per LBMS (below)
I am building a Western Foederate Roman based on the Gallic legions (425-460 CE), which want to extend to the Gallic Roman Foederae (460-480 CE). I am aware that the (early) Gallic Legions had 'regular' shield patterns as specified, but am unsure if these continued during the latter period. Am aware that Constantine introduced the Chi-Rho pattern, and that this was applied on a unit by unit basic.  Have used the LBMS transfers below for some legions and question what time period (apart from sub-Roman British) is appropriate for them
Many thanks
Whilst beloved of wargamers the Chi-Rho symbol was not in fact much used by the "later Romans" at all - if you look through the Notitia's western shield patters you will see exactly zero use it for example. The possible/probable use of it by Constantine is just documented for 1 battle as I recall.
As far as I am aware the LBMS ones for the post-Roman Brits is not based on anything either other than, maybe, Arthurian mythology.
Personally I have gone with Notitia patterns for my Roman(ised) units in that period on the basis that there could have been continuity but equally you could use pretty much any Roman-Germanic iconography mash-up as equally plausible IMO. There are good arguments that the army that the Gallic Foederate army represents was just a Frankish army anyway ...
Ambiorix
Indeed, I find it personally very sad that LBNS and VVV shield transfers don't pay more attention to the details of the Notitia dignitatum as their transfers are often wrong, confusing legions with auxilia or are sometimes complete fiction.   A real pity as the Notitia dignitatum provides excellent evidence on the roman shield designs and their corresponding units.  Unique in ancient military history, so don't understand why transfer manufacturers don't adhere more closely to it....
IMO at best the Notitia is a guide and not a wholly reliable source - after all the versions we have available are all copies of a Roman original. Not blindly following it is not an issue IMO.
Ambiorix
True, it contains some inconsistencies but it is still based upon primary sources, so why 'make up' new designs if already many hundreds are 'historical' available...
