Ayyubid / Fatimid Magna List Minimums?
Started by Plantagenet, June 21, 2021, 11:33:31 AM
Plantagenet
I might be missing something here but there are numerous instances in the above lists (I haven't checked any others in the Crusades lists) where the UG size is 4 and yet the minimum number of bases that can be taken is 2?  How does that work?  Surely if the UG size is 4 and the troop type is mandatory, the minimum that can be taken is 4, or zero if a discretionary troop type?
There is an error in the minimums in these lists in the sense you have to take at least 4 to form the UG.  Not quite sure how that crept through.
Plantagenet
Quote from: lionheartrjc on June 21, 2021, 02:44:12 PM
Thanks.  I suspected that may be the case.  Either they had to be compulsory units in which case the Min would have to be 4 or they were optional units with the Min needing to be 0.
