Bow cavalry in battle but with come heavies to help Moncheaux 2019
Started by badhabum, June 21, 2019, 09:42:53 AM
Quote from: nikgaukroger on September 14, 2019, 07:47:16 AM
Quote from: nikgaukroger on September 12, 2019, 05:47:54 PM
If you need the punch (and most of us do) then don't pick an army without it - simples  ;D
Actually, I'd add that a chunk of "stodge" can also work wonders in a basically shooty cavalry army - basically something the opponent can't just push around.
I think I understand the meaning of the chunk of stodge- but not sure 100% - . If, as you write, we should choose not to pick an army without "punch" , then stop creating some . The rules work well but do the rules work in a 3 hour tournament . My answer would be yes and no . If the 2 players go for it , then it works. But with shooty armies on white dice, time is a bit short as you need time to roll the dice, wounds can be healed and so on.... Youn can weaken an army, but difficult to finish it . I am painting one of my favourite armies, the early byzantines. But it lacks the punch needed in a tournament . I made a proposal based on many reading and we will see what happens in 2020 . 8) . Now I am not the only one to think shooty mounted bows need something to go on . At Britcon, I was winning the first game after 3 hours, lost after something like 4 hours ( friday night ) and I faced some skilled shooters  ::). But the game was fun.
So
Robin
I cert agree that the shooty Cavalry armies need a heavyweight unit. At the recent London GT, Richard won the event with Timurid s and Nik came 3rd with Sassanids. Both had Elephants, to deliver the punch. I just wish I was good enough to use them.
craig.w
Quote from: Simon Meg-Meister on September 13, 2019, 03:12:14 PM
Indeed. Change in part is seeking to encourage a bit more without them being too good.
And the American armies with every man a shooter? They'll be getting slows all along the line. Shoot and charge troops will also be supreme skirmisher killers - even better than they already are. Will be interesting to see the result of this change. Once it's in it will be there for years...
We will see. Only a few more days to wait . Shoot and charge can make for a bad day for skirmishers but then you must adapt  and perhaps choose fleeing or position your skirmishing cavalry a little bit better . Which is not always an easy feat.
In 2017, with nikephorians, I used the shoot and charge to get at skirmishing cavalry more than once .
FWIW on of my most successful cavalry based armies was a Gallic with maximum average cavalry in 6s.
3x6 and 2x4 caused mayhem on a wing. by sheer weight of numbers.
Yes but you also had some warbands that can just glue the enemy . It's not the same .
Of course not total cavalry.
But  serious chunk of stodge flank.
