foot cb standing to receive, charge only shooters
Started by tarnowski1, November 11, 2024, 08:05:42 PM
tarnowski1
couple of questions to replenish my memory.
1- foot crossbows standing to receive a charge only class an S as a wound for those files physically being contacted by an enemy base?
2- Charge only shooters standing to receive and choose to shoot, only shoot those files being contacted by enemy bases?
1. Yes; as shooting is done by file this effect is applied by file so it has to be a shooting file actually contacted by a charge.
2. Yes; as the Shoot and Charge characteristic description in Appendix 1 (PDF) states "files".
so the 1 BW rule in the path of charge, for an overlapping base not being charged, does not apply?
It applies to whether files not being charged can shoot, but not to whether the S = Wound applies.
Hayung_is
So for super clarity;
1. the file must be getting charged to get the S=wound characteristic of Xbow.
2.a. Charge only shooters can shoot if the TuG is standing to receive and the path of charge is within 1BW of the file.
       or if they charge and are within range.
   b. Shoot and charge shoot if within 1bw of the path of charge just like regular shooters (because they are).
Quote from: Hayung_is on November 12, 2024, 01:44:06 AM
This seems clear now, thank you
Yes. (and standing to receive)
Files of Charge Only shooters standing to receive can shoot when being charged - so this is basically the same as the crossbow case.
Indeed.
The characteristic definition for Shoot & Charge from the PDF to assist.
daveparish
So does that mean that a Charge only shooter 3 wide who charges a two wide opponent might only get two shots (the two files who contact)? Would you potentially need to do a cheesy wheel so that all three bases contacted the two enemy bases in order to get all your shooting?
daveparish
#9
 I see that the "files"  part says when standing to receive or when charging. So it could mean that
When charging they use the usual rules for targets (see 1 in the description of the characteristic which mentions in arc) so it isn't just the bases that contact.
It is a tad messy to be honest  :(
daveparish
Are you sure? Point 6 in your quote above says when standing or charging
imho it is complicating things, the standard rule application would be easier to apply, less exceptions
daveparish
Quote from: Jilu on November 12, 2024, 10:03:10 AM
Sorry I don't quite understand, what is the standard rule application? (not trying to be rude, really don't understand)
tarnowski1
Quote from: daveparish on November 12, 2024, 09:42:11 AM
It does seem to suggest that shoot and charge shooters, shoot any one in arc and range as per 1 but charge only shooters are further limited to those that would make contact in the charge as per 6
