Can there be flank marches and ambushes when there is no outscouting?
Started by LawrenceG, January 18, 2023, 07:25:06 PM
PBS5.E.3.1 and PBS5.F.1 say flank marches and ambushes are set up "after the outscouting deployment" or "after the initial deployment done by an outscouted player "
If there was no outscouting, so there is no outscouted player, does this mean you cannot do flank marches or ambushes?
PBS5 A gives the general sequence with the other sections slotting in as needed.
Whilst it may be that the wording can be tightened, I think that the situation is pretty clear and that you can flank march even if there is no outscouted player.
Quote from: nikgaukroger on January 18, 2023, 07:44:17 PM
Well, that seemed most likely, but in addition to the two places I cited above, PBS5.A.3 says "after outscouting" and the table at PBS1.B has FM&A in the sequence after the outscouted player deploys, but not after "If there was no outscouting, the defender begins placing his camp and ⅓ of his UGs as above...", which was enough instances that I thought I had better check.
