Close and Loose Formation
Started by mikecobden, December 14, 2022, 08:41:12 PM
mikecobden
Hi all,
I have been re-reading the rulebook, and playing solo trying to figure out some things. My current question is why one would choose to deploy a TUG in close if the unit was flexible? As far as I can tell, close formation only has downsides (elephants and terrain). So why would I ever deploy my legions in close formation? What am I missing?
As always, thanks for the help!
Mike
Two reasons:
Cavalry, camelry and chariots get +1 at impact vs loose foot.
Loose foot can be shoved by close foot in 2+ ranks.
mikecobden
Thank you for this response! And as always your responses on this Forum are very fast and helpful.
I found the close order shove rule, but it is all the way in the back, in the appendix, under "shove". I would never have thought to look there for clarification on "close order versus loose order"! :)
sstoker22
I an just looking at this but not loose are cheaper pts, Less affected by terrain, move faster in difficult going and fair better against elephants  (except drilled). For the 5pts cheaper a loose unit is you can nearly buy a short spear which offset the close advantage v cavalry. But also give you an advantage v others.
I note flexible pay a higher pts penalty
