So as I believe it stands the current plan is to reduce the KAB tests in Pacto by two colours.
I think this is the wrong approach.
It is my belief that the issue of massive cascades in Pacto is not down to the dice but a combination of the width of Unit Groups and the range of KAB tests. ( Caveat I play Pacto in 15mm)
What this results in is a higher frequency of double or triple KAB tests where as in Maximus it would not.
Therefore my view is in the camp that cab tests should not be reduced in dice but the range restricted to being 2cm instead of 6cm.
The reason is I play Pacto to have quick fun games and all reducing the dice colours does is slow down the game and remove the brutality.
