lurkio romans/bysantines and shield transfers
Started by Jilu, March 01, 2019, 06:31:14 PM
Hello does anyone know what shield transsfers to buy, lurkio  advertises a LBM reference that i cannot find on the LBM website.
thank you
RocketSix
Nathan
I emailed LBMS to ask what size their Late Roman shield transfers were so I could decide which, if any, might fit my old Minifigs figures and received this reply from Steve:
There are two sizes on the Legio Heroica sheets.
   The largest:- 13mm high and 8.5mm wide
   The smallest:- 12mm high and 8.5mm wide
The Khurasan shields are :- 11.5mm high and 8.5mm wide
RocketSix
The Lurkio shields were designed to fit the LBM LIRA decals
Since the question is cropping up due to the PSC release here is Nik's guide to transfers that work with the first batch of PSC plastics:
For the Romans the transfers from the LBMS Khurasan range fit, as do the small shield ones from the Legio Heroica range FWIW but they only comprise half a sheet.
For the Goths the LBMS Khurasan Viking and Saxon ones fit and the Khurasan Germanic ones fit those figures with slightly larger shields. Additionally the ones from the LBMS Essex Dark Ages fit as they are smaller than the shields (so you have more rim to paint after).
Sasanids and Huns - none. FWIW the shields on the Sasanid spearman figure paint up nicely without the need for transfers due to the modelling detail on them.
The VVV waterslide transfers will also fit from the Late Roman and Byzantine ones for the Roman figures and also (I think) the sheet of generic round shield designs will work for the Goths.
