Belgian proposal one simplifying melee when already in contact
Started by badhabum, October 05, 2025, 07:25:26 PM
Simplifying engaging in melee when already in contact
We would suggest that a TUG corner to corner contact with an opponent and "engaged" as a supporting file only could move 90° to engage the flank of the enemy TUG ( simplicity )
Thank you for the suggestion.
I assume this would be in the movement phase and not treated as a charge.
Will add this to the list of possible future changes.
tarnowski1
Quote from: badhabum on October 05, 2025, 07:25:26 PMSimplifying engaging in melee when already in contact
simplicity would be leaving the rule as it currently stands.
Quote from: lionheartrjc on October 06, 2025, 08:17:27 AMThank you for the suggestion.
yes movement . For some reason or another, we played it that way for years . Then it either changed or was clarified and so could not be done anymore .
But it seems "strange" and counterproductive not to allow it if there is space, enough movement distance
Glactophagos
Let's fight on the table, not on the forum.
Manzikert
If the goal is simplify then maybe just specify that a UG can provide a supporting file without becoming 'engaged'. Then the unengaged TuG is free to move, probably onto the flank of the unit they were just overlapping.
