Re: 2026 Proposed Amendment - Hoplites
Started by lionheartrjc, September 15, 2025, 09:47:52 AM
Quote from: Munster on September 15, 2025, 09:19:41 AMIf you want such a major change (and some of these are quite major not clarifications) I would suggest playtesting a full V2.0 recognising that V1.x works pretty well, and that tinkering will never satisfy everyone and constant tinkering may drive away your player base.
I have done a lot of play testing of these amendments for well over six months.  Have you actually played any games with the amendments?
Hoplites were not playing correctly under the existing rules. Too good against mounted and not good enough against foot. The games we have played with hoplites using the amendments have worked really well.  Even against "heavy" cavalry they are far from a pushover. +2 claims while in 2+ ranks at both impact and melee - legions with melee expert are only +2 at impact, +1 at melee.  Remember they can be in 9's and the cavalry will generally be in 6's.
Quote from: lionheartrjc on September 15, 2025, 09:47:52 AM
This is the LS discussion not the "spear" discussion . But mixing periods I would say yes there is a problem as shieldwalls did have the same flank problems as hoplites : unprotected right flank and a tendency to go left
Munster
Quote from: lionheartrjc on September 15, 2025, 09:47:52 AMI have done a lot of play testing of these amendments for well over six months.  Have you actually played any games with the amendments?
Richard, thank you for your play testing.
Having typed several responses to your statement, I shall simply bow out of the discussion
