dismountable cavalry
Started by badhabum, February 12, 2023, 07:41:05 PM
QuoteMounted TuGs with dismountable can be dismounted at deployment for free.
It's an old discussion that for some reason comes back !
One player argued that dismountable at deployment means at the end of the whole deployment phase.
I pointed out that it has been discussed and that the intend is to be deployed dismounted when the UG is deployed , placed on table. previous discussions point that way.
So if I may suggest a small add to the rule PG 128 pdf to specify "to be dismounted at initial deployment when the IUG is placed on the table" . Sometimes you must insist
regards
