Cards in a pack
Started by LawrenceG, January 18, 2022, 10:03:52 PM
Apparently a MeG pack does not match the composition given at https://mortem-et-gloriam.co.uk/meg/colour-command-combat-system/
Has the standard for all games been revised since that article was written, or will there be a different pack for each game?
Would it be worth updating the article?
Ambiorix
FYI, I have not checked the composition of the cards (as I only use tokens). The supplied tokens have an extra piece of each colour (in case of 'attrition'?) which I keep aside. Is this maybe the same for cards ?
The pack should have 6 Red, 10 Yellow, 14 Green, 12 White and 8 Black cards.  This has never changed as far as I am aware.
Indeed, and what the pack I have contains.
Quote from: lionheartrjc on January 19, 2022, 07:24:25 AM
The article I linked to says 6 Red, 10 Yellow, 12 Green, 10 White and 8 Black.
Could do with a tweak then :-)
Can you post linked to the article so i can get it corrected.
