Calculating PBS map and scouting cards
Started by Sillyflower, October 29, 2021, 04:26:05 PM
Sillyflower
I sure I am not the 1st to raise this issue but I haven't found the answer on the forum
I have libra office but the MEG spreadsheet doesn't accept it, and I'm not going to pay £80 pa to get excel for which I have no other use.
So how do I calculate these values for my armies?
Sillyflower
I know I'm useless at this sort of thing.............
It comes up as a .ods file and I can input the correct version (PACTO) generals and the 1st unit line and get the correct points values
Then that's it - can't input anything else
Maybe I need to see someone else doing it
garethe121
I don't have excel either so I downloaded the file and opened it in Google Sheets. It then works fine. Google sheets is the free spread sheet app on google
SimonStokes
XLSX file works fine on Google Sheets. When you come to print your list however you will need to select  the cells to be printed and then use the sheets "print selection" option.
