Terrain sizes - Pacto?
Started by Plantagenet, September 14, 2020, 09:13:47 AM
Plantagenet
Still waiting for my book to arrive (we play still as others have it already) but I'm scouring through trying to find the terrain sizes for Pacto?  Can't see it on the either the Pacto sheet or the PBS sheet but I'm not sure I'm reading something wrong on the PBS as underneath the Magna line about terrain it talks about base widths not needing to be changed for Pacto, but I think that refers to element bases not the terrain?  If Pacto terrain sizes are different it would be useful if they were on the sheet, even if it's the same as UG reductions (e.g. 2/3).
ShrubMiK
All of the quoted distances and dimensions are the same in Pacto, but the actual distance represented by a BW is halved. (i.e. an element base is two base widths wide ;))
Thus the terrain pieces for Pacto should be halved in size in both dimensions.
Plantagenet
Thanks, yeah, the penny dropped last night.  Brain been working overtime this week juggling lists for a purchase so the army can be used for MeG but also DBMM and ADLG should the need arise, stuff just not sinking in.  Was totally missing what BW had to do with terrain.  Can't help thinking the how the terrain applies to PACTO could be explained a bit more clearly than it is currently on the PBS sheet, something along the lines "Due to the BW for Pacto being reduced by 50%, terrain features will also reduce in size by 50% comparative to Maxima".
