ILKHANATE ( in Ghengis )
Started by Onurbm, January 31, 2019, 09:43:24 PM
Onurbm
There is a crusader  general  as "internal ally ". he becomes mandatory if knights are used . but nothing is pecified as to which troops this general may or must command .
i would assume he has to command knights and crossbowmen but this is not specified . And what about other troops ? kurds ? mongols ?
As an internal ally he should command some of the Cavalry and some of the Best Cavalry ( does he ? ) and may command any other ... does he really ?
Thanks ... considering using Ilkhanate in Chaniers in March 2019.
Bruno
GANDALF
A Crusader ally general may only command troops in the section marked "Crusaders".  I think that is pretty clear.
Onurbm
#2
Perfect, thanks, exactly the way i understand things . I will use your note to support my point if required ;D
Bruno
GANDALF
