Finding the List You Want
Started by lionheartrjc, May 15, 2020, 10:12:04 AM
In response to a query.
The way that the lists are compiled prevents including a link in the table of contents.
If you need to find in which list set a particular army list is then use the Army List Index.  This document has all the army lists sorted by set, alphabetically and by date.
In any of the PDF files (including the index), use the Find command (Ctrl-F) to go straight to the list you are after. All the text is searchable.
The thumbnail view can also help to navigate down the document quickly.
Hope that helps.
